bug normal map between gpu/cpu
  • bug normal map between gpu/cpu
    baptiste_rouglauth1 17-01-2022, 11:49 AM
    Hello,
    i have a bug, i think, between render cpu and gpu.
    I have a proart D940MX station by asus with I7 7990K 64go ram and quadro rtx 4000.
    And on a bark texture, i don't have the same result between cpu and gpu, it's look like the normal map is not using on cpu render, and on an other texture i have a white filter on this. I let you see the render and the render settings for the normal. i use the rendering space (linear) for the normal map color space.
    I can add something! i juste find that is using on the vraymesh, but not on the fbx mesh.
    Thank you for your help
    Can you please share an example(with the maps included)?
    If the file ends up being too large you can use the link below to upload it.
    https://support.chaos.com/hc/en-us/requests/new
      Here is the wetransfer link with the files.
      https://we.tl/t-rhVLxI9bhU
        Can anyone help me?
          I am reproducing this on my side as well. I report this in the internal bug tracking system.
          As a workaround(kinda) when possible don't use proxy but a regular mesh.
            Hi again,
            The issue is reported under VRW-3600
