Extra Lines Showing Up in Render
  • Extra Lines Showing Up in Render
    I am trying to figure what is going on in Vray.
    I use Vray a good bit in SketchUp, and have my own generic material for making stylized renders - its a grey with edges on and a bit of dirt.
    I am trying to convert solely to Rhino to save some money and it would be super cool if I could model and draft in one eco system.
    But I can't figure why Vray in Rhino is picking up all those extra lines, any help would be great
    Someone on Reddit mentioned turning off Isocurves. But same results
    This is the Rhino Output
    This is my display in Rhino
Name:	Screenshot 2024-07-20 224141.png
    This is how the surfaces should look (had to Render in SketchUp)
    What type of geometry is that? Nurbs or Mesh? In the upper image is that out of VRay or a shaded Rhino view?
      The geometry is closed solid polysurface and the upper image is out of Vray
        That's very odd. Is this in Rhino 8 or 7? Can you share the model? The Rhino shaded view looks like clean nurb surfaces, while the shaded rhino view looks to be mesh geometry or mesh that was converted in to polysurfaces.
          https://www.dropbox.com/scl/fo/o5a78...1menl1isf&dl=0
          Sure, its a Rhino8 File
            I just tried it out and it looks totally fine in both Rhino shaded view and VRay. It may be some odd glitch in Rhino 8. Try saving down to Rhino 7 to test (if you can) or open a new file in Rhino 8 and copy the geometry into that file to test. I have found that it sometime resolves odd issues like this.
              Did you use the material as the generic override?
                I did and also added edges in VRay to test and a Rhino shaded view with edges on. All looked good to me.
                Straight from RHino:
                VRAY with edges on.
                  Well, that's frustrating for me.
                  I dropped it in a new file, tried in 7, tried a new file in 7 as well.
                  What a pain
                    I noticed that the geometry is all blocks. have you tried exploding all of them to see if it's an issue with how Rhino is reading old block geometry?
                    Here is a link to my version of the model as well as one with all the blocks exploded. Not sure is will help but try it out.
                    https://drive.google.com/drive/folde...usp=drive_link
                      Blocking everything was so the geometry came in as decent groups in SketchUp, as opposed to one giant blob
                      You are going to have to grant me access
                        Yup sorry. Just changed the link to share the folder with both files in it. Hope it helps!
                          I wish there was a way I could compare just the settings between the files, because the worked like a charm
                            Glad it works now!
                            • #15
                              Wait, nevermind - just turned the material on and the lines are back
