today I have try the tutorial:
http://www.spot3d.com/vray/help/VRay...ials_imap1.htm
Hmm, the interface confuse me. After some test I know now, if I set "new map" than I must set extra "auto save". But why is it not in the same option frame?
Also I'm confused from the two path options. The upper path is only needed for "from file" or? If the upper path is used for "from file" only, than I would wish the path option is written in the same line with "from file". Also the two frames around the options confuse me.
If I understand the concept right, than I would make one option frame for write and one for read.
Back to the tutorial: I can not find the "single frame" mode for Irradiance Mode.
-Micha
-Micha
