What is this for? Is it for speeding up LC on multi processor machines? If yes, I think you loose all the gained time during the 'merging LC passes' phase. This takes a long time already for low subdiv LC solutions, must take vray long on high quality LC's...
num passes in lightcache
Tags: None
... an other disadvantage of more than 1 pass is, that I can not estimate the quality of the LC, because every new pass start at a low quality level.www.simulacrum.de - visualization for designer and architects
I don't notice that it starts over again?
How many passes do you set it to? I think you shouldn't go higher than the number of processors you have. A HT enabled proc means 2, a dual machine with HT = 4.
Thanks Wouter, I know.www.simulacrum.de - visualization for designer and architects
Ok, but why then does your LC calculation start over?
I use a dual core machine with 2 passes and after the half LC pass, the noise level jump and clear up slow again. It's not a big problem, but with a single pass I can see the full quality of LC at the end of LC pass.
I think, if the LC pass is to noisy, the primary engine need more time to clean up the rendering or? What do you think?www.simulacrum.de - visualization for designer and architects
The primary engine will try to use the LC info, and if it is too noisy and incorrect, this will get carried on in the primary GI calculations, I think.
Any idea what the adaptive option in LC parameters is?
Mmm that merging is getting on my nerves hereIt takes about the same time as the actual calculation time!
Originally posted by flipsideMmm that merging is getting on my nerves hereIt takes about the same time as the actual calculation time!
VladoI only act like I know everything, Rogers.
Ah yes, I see. The progress also starts very fast, but it slows more and more towards the end.
Originally posted by vladoOriginally posted by flipsideMmm that merging is getting on my nerves hereIt takes about the same time as the actual calculation time!
VladoBest regards,
Joe Bacigalupa
Developer
Chaos Group
I am using Micha's awesome tutorial for rendering exteriors. I initially set the number of phases to 1, but the Render Progress box says:
"Performance loss: number of rendering threads (2) is less than number of light cache passes (1); some threads will be idle."
Does this mean anything for the quality in the end?
Best you set the phases at the number of CPUs/Threads you can use. For a dual core is it 2 here.www.simulacrum.de - visualization for designer and architects
