DXFs and textures
  • DXFs and textures
    Can textures be applied to DXF models,
    Regards
    Mark
    DXFs and textures
    i don't know,
    but for some 3ds that was not working at first sight, I use meshtonurb command and then do what you want.
    Freelance Industrial Designer - Rhino3d v4 - Vray for Rhino
      DXFs and textures
      I had a problem some weeks befor - an imported mesh dosn't show textures. I have find two ways:
      - export the object to the free tool UV mapper and assign a mapping
      or
      - use David Ruttens Displacement scrip that support reassign of texture coordiantes (http://www.reconstructivism.net/). It is a dotNET plugin and you must install the dotNET manager befor.
        DXFs
        Hi JP / Micha, thanks for that, just needed to have it confirmed that DXF were giving a problem with textures, I hope I can salvage my old DXFs to use with V-Ray as I have lots of them, window frames, doors, mouldings etc.
        Thanks very much
        Mark
          DXFs and textures
          If it's the texture coordinates causing the problem, why not just assign a rhino mapping, box or planar or something?
            DXFs and textures
            If an object has no UV coordiantes, than the RCM mapping tool dosn't help. My tests has shown me that the RCM tool manipulate the exist UV coordinates, but dosn't create new.
              DXFs and textures
              I'll report that as a bug if you can provide me a scene to verify that. My gut reaction is that doesn't sound right, but I'm not sure.
              Joe Bacigalupa
              Developer
              Chaos Group
                DXFs and textures
                Please look here.
                http://news2.mcneel.com/scripts/dnew...&/bathroom.rar
                  DXFs and textures
                  I was able to apply UVs to the groundplane (L640_OBERF) - I'm guessing thats what you wanted to map? I just went to Mapping->Show Advanced UI-> Add Channel. Then I set it to repeat 5 x 5 and applied a checker texture. It worked fine.
                  Was I trying to apply mapping to the wrong thing - or am I just misunderstanding what you were saying?
                  Joe Bacigalupa
                  Developer
                  Chaos Group
                    DXFs and textures
                    Interesting. I have done a new test. Import the 3ds model, select the ground tiles, hide all other objects, set rendered viewport and assign a texture per rhino material options - nothing. Than I have set per RCM "planar" and repeat. Nothing. Than I have create a planar surface and assign my texture ... and I'm not sure when, but after I have play a little with the planar surface, the mesh object show me my texture too. Interesting. After a while of playing I have delete the RCM mapping of the mesh object, but the viewport show me my tiled texture. Something works not stable here.
                      DXFs and textures
                      Odd - In my workflow I also created a plane to compare the mapping against - I guess thats why I had success immediately.
                      Joe Bacigalupa
                      Developer
                      Chaos Group
