For those people that use gamma correction, you should be aware that gamma correction also affects the reflectivity. If, for example, you want to have a 50% reflective object, you can either do one of the following:
Set the reflection color to rgb 56,56,56 or:
use a bitmap in the reflection slot (can be a small one like 40x40 pixels) with an rgb value of 128,128,128.
