Batch Render for Rhino
  • Batch Render for Rhino
    This is a repost from an old thread that's burried deep in the forum. It should help some people access the Beta and unsupported Batch Render tool.
    Simple steps to batch rendering:
    Once you download the Batch Render Plug-In (beta) here (thanks again Micha): www.simulacrum.de/download/BatchRender.zip
    You should install it through the plug-in manager in Rhino (Tools > Plug In Manager ...)
    Now you can simply type BatchRender in the command line and you'll be presented with a simple Dialog Box allowing you to add files and pick views (which can be saved if you right click the viewport name and click 'named views ...'). The settings are very straightforward.
    *** Important Note ***
    So far I have had two large batches completely screwed up because I did not verify that the 'Batch Render' Dialog was selected in the vRay > options > Global Settings dialog. I often uncheck this option so that I can work on my scene while it's rendering, btu it causes nothing but trouble during the batch render process.
    It would be very helpful if future versions of this application ensured that this option was enable automatically (or simply overrode existing file settings).
    *** Bugs ***
    The View Selection dialog box often lists the selected view twice
    (once at the top of the list, and again at the bottom of the list). This is scary, but I select another view, then the one I want.
    If the Batch Render option is not enabled, the render process will continue to open all files in the list, while still rendering the one that lacked the batch render option. It will then save out the render with an incorrect file name (the last one on the list usually), and the Batch Rendre window will report that all of the renders were completed successfully. This is a lie Wink
    [edit by Joe B]
    I changed the name of the thread form Batch Render for Rhino 3 - just to Batch Render for Rhino
    Re: Batch Render for Rhino 3
    I stickied this topic since the batch render tool has been coming up a lot lately. We're working on porting it to Rhino4 as well.
    Joe Bacigalupa
    Developer
    Chaos Group
      Oh yes, it will be a great help to get more sleep.
      (Some times I get up at night and start next renderings and sleep again a while and ... )
        Ok - so the freshly revamped batch render tools are now available in our Tools section.
        There is a known issue right off the bat, but I think you've all waited long enough for this already so I've posted it as-is.
        Issues
        - it seems that saving some of the new file types isn't working properly with our VfB
        Joe Bacigalupa
        Developer
        Chaos Group
          ;D
          Thank you Joe, now I will get more sleep. Great.
            Hmm, sorry if this is a stupid question, but Ive read the first post about 100 times, and I checked that all my files have "batch render" enabled about a million times. And it still only renders 2 views out of 12.. I have 4 files to render with 3 views each.. does anyone have any suggestions, because I need the sleep
              I'm having similar problems.
              I've read in past ASGVIS posts that you need to make the saved views active in the viewports. But, aside from adding extra viewports, this limits me to batching only 4 renderings. Is there a fix to this problem? A de-bugged version of the software? Any updates if this is being worked on by ASGVIS?
              I've also heard rumors of users altering the software's code to fix the problem. Anyone seen a version that did this and worked?
              Thanks!
              Josh
                what is batch render???
                Pleas let me know
                THX
                  quote
                    just tried the tool yesterday. I currently used rhino 4.0 and checked the batch render switch....but I arived today to get a surprise....just the last render is saved. I saved and restarted the file to try again.... does this tool work for rhino 4 as well?
                      Ok, I solved the issues and now I can render a lot of imagens in one single file..... but does this work across multiple files?; What I mean is, can I render views form other files with the same batch?
                      Thx in advance for the help I can receive
                        Hello all,
                        sorry but can anyone tell me if there is a way to batchrender with Rhino4 and Vray,
                        the plugin mentioned in the first post could not be installed...
                        best regards
                        Chris
                          Is this batch render tool compatible with Vray for Rhino SR1 RC2?
                            Yes, although the batch render is getting a little face lift. So although the old one should work for you, there should be a revision floating around in the coming weeks.
                            • #15
                              I installed the plugin but how can I use it
