Hello All
I have a little coffee-table I designed that I'd like to make a rendering of. The problem is that the top surface is a relatively complex curve and it's supposed to be a wood veneer which would make it very uniform. Unfortunately it's seems to be stretching around the legs(see attached images)
You should also know that the curve is not actually a single surface but a couple of surfaces joined together.
Any advice would be greatly appreciated.
Wouter
Wouter
