Vray Emissive Material Problem
  • Vray Emissive Material Problem
    I can't create an emissive material. I followed the vray for rhino manual but i can't obtain the same result. Are there any special settings to set in vray render options like illumination or similar? I want to create a red led light and a screen illumination, something similar to ipod. Please help me! ??? ??? ??? ??? ???
    Re: Vray Emissive Material Problem
    Maybe you use the phys cam and than you must set the intensity of the emitter material very high - try 1000 or more.
      I set the intensito to 1 or maybe 2... i will try with 1000 :
        Yes it is a bit of a hassle. We're planning on supporting physical light units as soon as possible. This should make it a bit easier to gauge proper intensities for a given exposure.
        Joe Bacigalupa
        Developer
        Chaos Group
          This is the result T obtain with 1000 of intensity... I'm quite happy... for a simple test
          How can i color the light? Some texture or any special setting in the materials?
            Assign a texture to the emitter material. For making materials read the tutorial here:
            http://www.asgvis.com/index.php?opti...d=30&Itemid=55
