I can't create an emissive material. I followed the vray for rhino manual but i can't obtain the same result. Are there any special settings to set in vray render options like illumination or similar? I want to create a red led light and a screen illumination, something similar to ipod. Please help me! ??? ??? ??? ??? ???
Vray Emissive Material Problem
Re: Vray Emissive Material Problem
Maybe you use the phys cam and than you must set the intensity of the emitter material very high - try 1000 or more.www.simulacrum.de - visualization for designer and architects
Yes it is a bit of a hassle. We're planning on supporting physical light units as soon as possible. This should make it a bit easier to gauge proper intensities for a given exposure.Best regards,
Joe Bacigalupa
Developer
Chaos Group
Assign a texture to the emitter material. For making materials read the tutorial here:
http://www.asgvis.com/index.php?opti...d=30&Itemid=55www.simulacrum.de - visualization for designer and architects
