Light at filleted Edges???
  • #16
    Re: Light at filleted Edges???
    Hi i was checking the bright thing. I dont know how to fix this...i also did an example with a filleted cube:
    [IMG]http://img410.imageshack.us/img
    410/6734/brillowk4.17632fd388.jpg[/img]
    Thank to all
    Zooropa
    • #17
      Your problem is the white reflection on the edge? I would say, it's a reflection of a reflection of the groundplane.
      • #18
        Hi Micha, no, thats not the problem, the problem is that the bright isnt correct. The direction of the reflection isnt logical. i did a Zebra Analize...and i if you look the cube you can realize that the different faces have another type of bright...it looks like different elements.
        Thank you
        Zooropa
        • #19
          Hmm,I don't understand the problem. Could a screenshot of the zebra test help me?
          • #20
            Here i posted the different brights...may be I'm wrong, but for me this is not logical. It looks like different surfaces.
            • #21
              If you look the render, you can observe that the cube work with different directions...on the reflection...so i read the form...like..different elements...and not like a whole thing.
              Thank you.
              Zooropa
              • #22
                Looks like a typical G1 fillet reflection - try to use blend instead round for a smoother transition from the spherical corner to the cylindrical edge to the plane sides.
                For a simple test set the reflection environment at white - you should see the same white at all surfaces.
                • #23
                  Thanks i will try! I'll be back with news.
                  Bye!
                  Zooropa
