Texturing help!
  • Texturing help!
    Ho to everyone! I was wondering....how I can fit this bump texture to my exterior wall. I dont like the tile style.
    DO I have to change something of the png texture in photoshop?
    The material is from this forum download section.
    Texture Mapping:
    U: 20
    V: 20
    W: 15.
    THanks A LOT
    Zooropa
    Re: Texturing help!
    Turn on the mapping widgets and size to please...planar would probably do the trick
      Re: Texturing help!
      Your pattern is to small for the wall and so the repeating is visible. Try to get a better bump map. You could try to shot an own photo of a large wall area. At the www you will find tutorials "how to create seamless textures" ... good luck.
        Re: Texturing help!
        Thank you both. So ho the people use this kind of images? Dont understando...which Its a normal size for a wall?
        Thanks.
        Zooropa
          Re: Texturing help!
          One more thing is important when you use texture mapping. When you finished your work on model or models, select them and use - Shrink trimmed surface. Sometimes unshrinked surfaces gives incorect mapping, especially when using option - Size to model in mapping menu
            Re: Texturing help!
            Thanks.
            Zooropa
            I would say it's a bad quality texture, so only some beginners will use it. Size - it depends on the texture. If you like to show a fine noise only, than a small noisy map is ok. If your map show signifcant details, than a bigger area should be covered by the texture.
            For a simple but good wall bump you could play with a noise material based on a noise with two octaves and a high fequecy ratio between the tow octaves. The high ferquency for the fine ripple and the low frequency part for the irregular motar thickness.
            Here something to start - maybe you need to adjust the "size" option of the noise for your scene. The noise at the diffuse color isn't important and can be deleted.
            http://www.simulacrum.de/download/Wall_proc.vismat
              Re: Texturing help!
              Hey Micha,
              Where can i learn on the noise settings like octaves and so forth ?
              www.Top3Dstudio.com
              SU 8
              VfS 1.48.89
              Win 7 64-bit
                Re: Texturing help!
                I don't know. I know noise shaders from rederman alittle bit. So far I know the octave count let you control how many noise pattern are overlayed.
                One more hint: if I want to adjust a noise for bump mapping, than I use a test material with the noise at the diffuse color. If the noise pattern is right I use the settings at the bump too.
                  Re: Texturing help!
                  The thing is: I have a Wall, and I don't want a repeating tile..stye. I want my image fit the right size of the wall. So which are the steps to know the right size of my map?
                  Thanks a lot!
                    Re: Texturing help!
                    Tiling can't be avoided in any case - if your map is for an area of 2mx2m, than for a 2mx6m you need a tiling. Most the goal is to avoid a visible (!) tiling. And here you need a good map. (Or you use a procedural shader like the noise).
                    Some tools like Imagesynth helps to get a random pattern from a photo texture.
                      Re: Texturing help!
                      But you'll still need to render to see the changes you've made... right ?
                      www.Top3Dstudio.com
                      SU 8
                      VfS 1.48.89
                      Win 7 64-bit
                        Re: Texturing help!
                        Yes.
                        I forget to say - an other advantage of the procedural noise than perfect tiling is, that you are complete independent from mapping problems, the noise looks perfect homogenious everywhere.
                          Re: Texturing help!
                          Thanks for all your answers! By the way Micha, Why your wall matrial...has differents types of settins...between difuse and bump?
                          thanks.
                          Zooropa
                            Re: Texturing help!
                            Because I thought at a wall bump and color are different effects, the diffuse noise was for an "used" effect, but isn't realy needed.
                              Re: Texturing help!
                              Thanks Micha, for your patience...I 've just realize that my question was really dumb.
                              Thanks ;D
