Sunlight system problem
  • Sunlight system problem
    Since last month the sunlight in my scenes isn't working... the render has the correct illumination, but in the areas where the sun supossed to appear there's nothing but a little spot of sunlight... I've tried a lot of different v-ray settings, but still not working, and it's annoying, badly! I'll really appreciate any help...
    Re: Sunlight system problem
    Hi shevu,
    Do you use the physical camera? You need to use this camera I think with the sunlight system. I have had the same and using the physical camera helped.
    Also you have a lot more settings like with a real camera that will help to make a realistic render.
    Hope this helps.
    Greetings,
    Martin
