Floating License for Telecommuting?
  • Floating License for Telecommuting?
    I work from a home office (current License holder) and my down-town office. I am looking to set up a floating license over VPN or similar at the office as I'm now doing more renderings here but still reuire it at my home office. I've read this can be done over VPN just curious if true and how to set up. Or other options
    Thanks,
    I
    Re: Floating License for Telecommuting?
    we only offer support for setting up a floating license to work across a LAN. As long as you are able to communicate with the server specified, you should have no problem checking out a license. I connect via vpn and use a floating license server that is at the office when I telecommute. A regular vpn connection should just make it so you can communicate with the computers at your office as if you are on the same local area network, so using a floating license server over vpn shouldn't be any different than using a floating license server on the local area network. If your vpn requires anything more than that, you'll have to have an IT guy figure out a solution.
    Devin Kendig
    Developer
    Chaos Group
      Thanks Devin,
      Is there a Thread for this process?
      Cheers,..
        For how to set up a floating license server? Like I said, we don't offer support on vpn stuff, just local area networks. So we can help you figure out how to get it running on your local network, but if you encounter any issues while using a vpn connection, that is beyond our realm of support.
        What we support can be found in the installation manual on our support page
        Devin Kendig
        Developer
        Chaos Group
