Hi All,
I tried installing the bew build on my just loaded Rhino 5 release version. When I do so near the end of the install I get a pop up box that says
"Problem running post-install step. Installation may not complete correctly. Error running c:\users\chuck_64\AppData\Local\Tempvcredist_vs201 0_x64.exe/q/norestart: Program ended with an error exit code."
And apparently they are right because Vray does not load with Rhino and is not available as a render option. I actually tried loading it twice. The first time I tried loading it over my previous version of Vray allowing the program to "uninstall" whatever it asked to uninstall. The second time I went into windows and uninstalled both Vray and the wibukey program. Both times the installed failed in the same way.
Any thoughts would be appreciated.
Thanks
chuck
Thanks
chuck
