rendering sketch up model
  • rendering sketch up model
    I downloaded a piece of furniture from google's 3d warehouse, and I imported the sketchup file into rhino.
    However, when I try to render my sketchup model in rhino using v-ray, the model doesn't render.
    It is invisible in my v-ray rendering.
    Why is this? How can I fix this problem?
    I'd appreciate your help!
    sometimes sketchup materials don't render properly in vray for rhino - the meshes look one-sided or inside out. try assigning a new material to the geometry. make sure you explode blocks first.
    emil mertzel
    vray4rhinoWiki
    Lookinglass Architecture and Design
      Thank you so much for your help.
      Assigning new materials worked.
      Thank you.
        Steps to resolve this issue:
        1.) Explode & Ungroup the object.
        2.) Select the object.
        3.) Properties > Material > Assign material by "Layer"
        4.) Assign your own material to the layer which has this object.
          answer from an expert:
          "Most of the time when this happens, it is due to a corrupted materials. Go to Global Switches and enable the "override materials", if you are able to see the render, then it is a material issue, if you still getting an invisible render, then could be geometry."
