Wish: 3D procedural noise
  • Wish: 3D procedural noise
    Maybe I have overseen it - I'm looking for a 3D noise texture which doesn't need proper UV coordinates - for example at this implantat. Could be a great helper to see it at V-Ray.
    Micha Just use a vray noise texture and set texture coordinates to 3d world xyz
      Great, I have completely overseen this option. At the help pages there can be found no word about it. Do you know - doe's the 3D object space work too, so that objects can be animated and the 3D coordinates follow the object?
      georgi.georgiev Could be nice if the 3D texture placement could be added to the help pages.
        Sure, use local xyz instead of world and it should work fine.
          georgi.georgiev konstantin_chaos
          I tested a local object space and moved the object a little bit -> the mapping doesn't stay constant. Please allow to use a local 3D space.
