Maybe I have overseen it - I'm looking for a 3D noise texture which doesn't need proper UV coordinates - for example at this implantat. Could be a great helper to see it at V-Ray.
Wish: 3D procedural noise
Tags: None
Great, I have completely overseen this option. At the help pages there can be found no word about it. Do you know - doe's the 3D object space work too, so that objects can be animated and the 3D coordinates follow the object?
georgi.georgiev Could be nice if the 3D texture placement could be added to the help pages.www.simulacrum.de ... visualization for designer and architects
Originally posted by Micha View PostGreat, I have completely overseen this option. At the help pages there can be found no word about it. Do you know - doe's the 3D object space work too, so that objects can be animated and the 3D coordinates follow the object?
georgi.georgiev konstantin_chaos
I tested a local object space and moved the object a little bit -> the mapping doesn't stay constant. Please allow to use a local 3D space.2 Photoswww.simulacrum.de ... visualization for designer and architects
