Wish: toon outline by distance -> start distance and min line width
  • Wish: toon outline by distance -> start distance and min line width
    From the old engine AIR I miss this two options. Quoted the description from the help docu. Additional an end distance could be great. So I could set line width attenuation from 3m...10m and min width 0.5.
    Fade with Distance
    Air can optionally make lines thinner as they become farther from the camera. Enable line width attenuation with distance by setting the fade start distance to a positive number.
    Start distance (default 0)
    Distance at which to begin reducing line width based on distance to the camera
    Min line width (default 0)
    Minimum line width in pixels for lines reduced by distance.
    Here an example - the first image show that without a detailed control no attenuation effect is visible, by the missing depth dependency it looks like the foreground lines are thinner than the background lines. The second image is a hack, where I changed the scene units to meters but kept the model length numbers, mm are m now. It could be great to get a full control per simple parameters.
