2 wishes
  • 2 wishes
    i think we should have a reflectlion pass in the v-ray buffer like in max
    and second, a ramp-like option should be very nice for fresnel effect !
    and third a little question :
    is vray limited to 2048 pixel wide for rendering ?
    it's a bit small for print output at 300 dpi...
    2 wishes
    previous beta builds of vray were limited. I can't recall the exact size it was, but there should be no more limits on the rendering. Are you experiancing something preventing certain resolutions?
    [edit]
    As far as the "reflection pass" I'm assuming you mean a channel that shows the reflections. That is currently unavaiable through the current VRaySDK materials. The same goes for self-illumination, refraction, and a couple others
    Joe Bacigalupa
    Developer
    Chaos Group
      2 wishes
      is it still limited to 2048 ?
      Jp
      Freelance Industrial Designer - Rhino3d v4 - Vray for Rhino
        2 wishes
        Nah - this was a long time ago. The only limits on resolution are your memory...and if you start going above your memory's limits then you just need to render to a VRImage.
        Joe Bacigalupa
        Developer
        Chaos Group
          2 wishes
          BrianPerry - 15 Jul 2006 What is the VrImage format?
          I saw it in output tab, but what happen after ? what are the gains ?
            2 wishes
            Here's Corey's tutorial on large res rendering/vrimage. http://www.asgvis.com/VfRtw/bin/view/VfR/TutorialA
            Basically with vrimage format each bucket, once its finished, is written to a file as opposed to a regular rendering where it is kept in memory. This info is also in a completely raw format, meaning that all of the information that is available/usable within the framebuffer is there (like a gi channel or refraction channel). Imagine the rendering equivelent of your camera's raw format. This also means that in order to use this format it needs to be converted. For download we have a vrimage to openexr format converter which can do this. Hope this is helpful.
              2 wishes
              kewl ! The only disavantage is that we need to convert... but hey for that much good stuff !
                2 wishes
                Here's a link to the converter.
                http://www.asgvis.com/VfRtw/bin/view/VfR/VrimgtoExr
                To be honest I haven't really messed with it. It always is a bummer to have to do a 4-8 hour test...then realize you messed up with one little thing. I'll get around to it though
