Any chance for a 'Section area render'
  • Any chance for a 'Section area render'
    Just a small wish, and I'm not sure if it's already been asked for, but is there any chance we could have the capability to do a 'section area render'? - similar to the one in Flamingo?!
    I've recently done a rendering which takes a long time to finish (even if I turn down some of the multipliers) - therefore If I make some material changes, it would be nice to 'select' an area to render rather than having to render the whole thing again?
    Cheers
    ... very easy to do now: use the "renderwindow" command.
      you can use the same one of flamingo works with vray
        Right-Clicking on the Render Button in the VfR Toolbar will get you the RenderWindow command
          Re: Any chance for a 'Section area render'
          It could also be nice to render an object. Quite often the scene is very simple, and I have to change some minor geometry. At the moment I use renderinwindow. However its hard to pick the exact same area to rerender if the first test wasn't quite right. If I could just rerender the object that would be great. It would also mean the shadow around the object doesn't render and it would save time.
          Regards, Gavin
