V-Ray NeUI has encountered a problem and needs to close.
  • V-Ray NeUI has encountered a problem and needs to close.
    I had this error message after a successful batch render finished (30 images).
    {"name":"vray-neui","hostname":"BPL31","pid":9780,"level":60,"er r":{"message":"EPERM: operation not permitted, unlink 'C:\\Users\\MARCO~1.KLE\\AppData\\Local\\Temp\\vra y-telemetrics (V-Ray for SketchUp).30-Sep-2018.log'","name":"Error","stack":"Error: EPERM: operation not permitted, unlink 'C:\\Users\\MARCO~1.KLE\\AppData\\Local\\Temp\\vra y-telemetrics (V-Ray for SketchUp).30-Sep-2018.log'","code":"EPERM"},"msg":"EPERM: operation not permitted, unlink 'C:\\Users\\MARCO~1.KLE\\AppData\\Local\\Temp\\vra y-telemetrics (V-Ray for SketchUp).30-Sep-2018.log'","time":"2018-10-07T00:00:00.004Z","v":0}
    Can someone give me a hint on what this might mean?
    **Software:**
    Version of SketchUp Pro is 18.0.16975 64bit.
    Version of VRay is 3.60.03.
    Windows 10 Pro
    **Hardware:**
    Intel i7-8700@3.2GHz 12 threads
    NVIDIA GeForce GTX 1080 Ti
    32GB RAM
    Thanks,
    Marco
    Hello, Marco,
    This appears to be caused by failure of the V-Ray UI (called NeUI) to delete one of its log files.
    In order to prevent clogging your hard drive with logged data, we only keep log files from the last 7 days. By default, every night (at midnight) a new log is created in place of the oldest one.
    Perhaps the oldest log file was in use, most likely by another instance of V-Ray for SketchUp.
    If you manage to reproduce the issue ever again, could you please do the following:
    1. Open Windows Task Manager
    2. Check the Processes list for any additional SketchUp and/or vrayneui processes.
    3. Open the Performance tab, select the CPU and check its Up time. Does the timer exceed 7 days?
    If the issue occurs often, you should be able to prevent it by deleting all V-Ray .log files in your Temp folder.
    We'll investigate this behavior on our end. Thank you for reporting it!
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Thanks for your detailed feedback.
      I will keep an eye on it.
      Many thanks,
      Marco
