VRay Next - Lights render very differently CPU vs GPU rendering
  • VRay Next - Lights render very differently CPU vs GPU rendering
    I've found that that the way lights render with GPU rendering, CPU rendering, and batch rendering with GPU is very different. If I'm rendering with GPU, the lights render with a very natural looking soft falloff around the edges. However, if I try to render with CPU, or if I start a batch rendering with either GPU or CPU, the lights render with a very sharp falloff that doesn't look natural at all. I've tried IES lights and cone lights with the same results.
    The light shown here in the attached images is a 5000 lumen spot light. The first image is a CPU rendering. The second is a batch rendering with GPU. The third image is a GPU rendering. All use the default rendering settings, except that I unchecked max ray intensity and am using auto camera exposure. The difference is visible when Vray is generating the light cache. I'm using Sketchup 2019 Pro and Vray Next. I installed the hotfix released yesterday but still having this issue. This appears to be a bug in Vray Next(never noticed this issue in 3.6)
    Hello,
    The problem is identified in the V-Ray core. Its ticket has just had its priority raised. It is identical to this one https://forums.chaosgroup.com/forum/...ort-the-insert
    We are currently debating on a possible temporary workaround for both V-Ray Next for SketchUp & Rhino. Will post an update in the next days as soon as the solution is deemed solid enough.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      A fix is currently being devised. It will be available in an upcoming update.
      In the meantime, you can overcome this sharp light cut-off by disabling the Camera Auto-exposure, lowering the EV value and then re-enabling the Auto-exposure toggle.
      If you encounter any further issues, please do not hesitate to let us know!
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
