Glass materials duplicate themselves when applied
  • Glass materials duplicate themselves when applied
    When using the default materials fromt he Vray library, they behave as expected but when using the ones from the “Glass” folder something strange happens:
    When applying one of these materials to a SketchUp face, either with SketchUp paint bucket tool or V-Ray’s “apply to selection” contextual menu option, the material (named, for example, “glass”) is indeed applied to the face, but a duplicate of that material is also created and added to SketchUp (named “Glass 1”). Every new application of that material to another face duplicate the material again, so that each face has essentially a different material…
    This happens to several of the Glass materials but not to the others (I haven’t tested them all…). When creating a new glass material (not from the default library) and giving it the same material properties in Vray, the same problem happens again with that material. Example of the material created from scratch but with that same behaviour is attached.
    I think this problem has been happening also with VRay 3.6 for Sketchup.
    Can you duplicate that problem?
    How can I avoid this problem?
    Thanks in advance for your help.
    Thibaut
    2hD Architecture Workshop
    My Config:
    SketchUp Pro 2019 19.1.173
    V-Ray for SketchUp 4.00.02 (build 97144)
    V-Ray NeUI Version 2.1.3
    MacOS 10.14.5 on MacBook Pro 13 (Late 2013)
    Hello, and thank you for your bug report!
    There are several known issues all leading to material duplication in SketchUp 2019. What you have described is one of them.
    You are correct. I have raised the priority on the dev ticket. A solution should be available in the next update. I'll get back to you if our developers can offer a temporary workaround until then.
    Kind regards,
    ​​​​​​​Peter
    Peter Chaushev
    V-Ray for SketchUp | V-Ray for Rhino | Product Owner
    www.chaos.com
      Yes, this is one of the most irritating bugs that has been here for a long time. I hope you get it squashed with the next update!
      Best,
      Peter
      AMD Ryzen 9, RTX 2080Super, ArchiCAD 24, Vectorworks 2020, Sketchup 2021 Pro, Vray Next for Sketchup, Skatter, Twinmotion 2020
        Just to be clear, this behavior stems from a SketchUp bug on OSX. You can follow its development here:
        https://github.com/SketchUp/api-issue-tracker/issues/62
          Edit: sorry didn't open your link to the GitHub discussion! Anyway it is good to see that it is noted by Thomthom.
          Best,
          Peter
