Vray often freezing during interactive rendering and it occurs not only in a specific project. I'm using vray in sketchup for almost a year and all of this time I hope that with a new update something will be fixed. Today I decided to make sure that no one of my plugins installed could conflict with vray and fully removed them from sketchup and then made some simple scene with one of my model and during manipulating with moving lights, rotating camera, etc. and finally after 10 or 15 minutes I got vray stop responding and SU too. The only way was ctrl+alt+delete and restart it. So I can be sure that there is no problem with plugins. Then I did the same on my other device and the problem is the same. It makes my work unreal because I always afraid of it will freeze when working with my projects and of course sooner or later it really happens. For example, I can model in SU for hours, for all the working day and no freezings or restarts but only I need to do the final step - rendering as it always becomes like a nightmare with all that freezing, bugs, etc. So what kind of information I could provide you in order you could find out with that really serious problem? Some log file or what else?
vray freezing during interactive rendering
Hello summerson1990
This seems like an issue, which will require a TeamViewer remote control session, so that we can properly inspect the problematic behavior. If this is alright for you as a course of action, please send an email to support@chaosgroup.com with a link to this post and mention somewhere in the email that you spoke to me regarding a TeamViewer session. That way the case will be assigned directly to me and we can schedule the remote control session.
Meanwhile, please make sure (if you are using an Nvidia GPU), that the drivers are the latest Game Ready Drivers downloaded directly from Nvidia's website.Last edited by Zahari.Ivanov; 08-06-2020, 05:03 AM.
Hello summerson1990
Thank you for the reply, I understand and agree with your position on this. In that case, the log files could be very helpful for us to see if anything within them will give us data relevant to the issue you are experiencing.
There are 3 types of log files, with which you can provide us:
1. SketchUp's log files can be found in C:\Users\USERNAME\AppData\Local\Temp
You should look for something along the lines of "SketchUpLog-2020-06-08-18_07_14". As you can see, they are recorded by date and time, so the latest one (right after the issue occurs) would be the relevant file.
2. The V-Ray log files can be found in C:\Users\USERNAME\AppData\Roaming\Chaos Group\V-Ray for SketchUp and the file you should be looking for is a text file under the name "VRayForSketchUp"
3. Finally, the Progress Log can be found if you click on the small rectangular icon at the bottom right corner of the V-Ray Frame Buffer. It has to either be copied to a text file or a screenshot could be taken of the contents. Unfortunately, due to the nature of the issue, this might not be accessible when the problematic behavior occurs.
3. Finally, the Progress Log can be found if you click on the small rectangular icon at the bottom right corner of the V-Ray Frame Buffer. It has to either be copied to a text file or a screenshot could be taken of the contents. Unfortunately, due to the nature of the issue, this might not be accessible when the problematic behavior occurs.Last edited by summerson1990; 09-06-2020, 04:26 AM.
3. Finally, the Progress Log can be found if you click on the small rectangular icon at the bottom right corner of the V-Ray Frame Buffer. It has to either be copied to a text file or a screenshot could be taken of the contents. Unfortunately, due to the nature of the issue, this might not be accessible when the problematic behavior occurs.Attached Files
Hello summerson1990
Thank you for the detailed information. We have one additional request - could you please provide us with a screenshot of your Window > Extension Manager window, as well as screenshots of the C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchU p 20XX\SketchUp\Plugins and C:\ProgramData\SketchUp\SketchUp 20XX\SketchUp\Plugins folders?
I have similar crash when using interactive...cpu or gpu. could be 5 minutes in or could be a half hour...but interactive rendering always crashes sketchup eventually for me. I'll be following this thread to see if you find solution.Core i7-8700K @ 5 GHz, Kraken X72, Asus - ROG MAXIMUS X CODE, Trident Z 64 GB @ 3000 MHz, 2x Samsung - 970 Evo, 2x EVGA - GeForce RTX 2080 Ti, Phanteks - Evolv X, SeaSonic - PRIME Ultra Titanium 1000 W, CyberPower - CP1500PFCLCD, 2x BenQ - PD3200Q, 2x Loctek D7L Monitor Arms, Corsair - K70 LUX RGB, 3Dconnexion SpaceMouse, Logitech - G602
Windows 10 Pro, Vray 5 for 3DS Max (latest), 3DS Max 2022 (latest), Vray 5 for Sketchup (latest), Sketchup Pro 2021 (latest)
Originally posted by GD3DESIGN View PostI have similar crash when using interactive...cpu or gpu. could be 5 minutes in or could be a half hour...but interactive rendering always crashes sketchup eventually for me. I'll be following this thread to see if you find solution.
