vray freezing during interactive rendering
  • #16
    Originally posted by summerson1990 View Post
    So please could you do the same switching off these two settings and try and say what's on your side?
    I just gave it a go. Unchecked both 'create backup' and 'autosave' and ran interactive rendering for probably over an hour and did not have any crashes. It seems that you may have found the culprit. Thanks!
    Core i7-8700K @ 5 GHz, Kraken X72, Asus - ROG MAXIMUS X CODE, Trident Z 64 GB @ 3000 MHz, 2x Samsung - 970 Evo, 2x EVGA - GeForce RTX 2080 Ti, Phanteks - Evolv X, SeaSonic - PRIME Ultra Titanium 1000 W, CyberPower - CP1500PFCLCD, 2x BenQ - PD3200Q, 2x Loctek D7L Monitor Arms, Corsair - K70 LUX RGB, 3Dconnexion SpaceMouse, Logitech - G602
    Windows 10 Pro, Vray 5 for 3DS Max (latest), 3DS Max 2022 (latest), Vray 5 for Sketchup (latest), Sketchup Pro 2021 (latest)
    • #17
      Thanks for taking a part. Yes, me too. I'm just right now having some test interactive rendering and me too not getting any crashes with autosave option disabled. But I also noticed that if I'm trying to save manually my project in a process of interactive rendering the issue goes back. So probably there is something wrong with saving process during Vray interactive rendering. And I can say that freezing doesn't appears at once I press "save" button. It appears sometime later. But surely there is some problem with the saving process @Zahari.Ivanov
      • #18
        So could you please too try to saving your project manually during interactive rendering and then do some manipulations you are generally do to wait if the bug appears again?
        • #19
          Unfortunately, some time later I get the issue back even I was not saving the project manually and still have "autosave" SU option switched off. But It became some less often even though. ChaousGroup support you have to investigate the problem. It's very weak that you can't let the log file show all the issues appeared during the working process. After that, I can't even suppose what else makes your VFB freezing during interactive rendering. If anybody else gets the same please submit this topic and please say about that. Let us make Chaosgroup and Trimble (if need) solve this serious problem. If we'll only look for messages and don't pay attention to it we'll not be having our working process best!
          • #20
            I've made a post here on SU forum. Please, anybody, who gives the same follow on it and say it. https://forums.sketchup.com/t/join-t...ndering/128458
            • #21
              @Zahari.Ivanov So what's the conclusion? I'm still getting this bug and you don't reply.
              • #22
                Code:
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T03:56:05.778104+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T07:45:34.9526681+03:00"}
                {"component":"app","error":"failed getting session secret: Get https://ols.chaosgroup.com/auth/token: dial tcp: lookup ols.chaosgroup.com: no such host","message":"Unable to refresh session secret","severity":"warning","time":"2020-06-13T12:28:33.6092468+03:00"}
                {"component":"auto_borrow_cache","error":"error downloading license cache bundle: Get https://ols.chaosgroup.com/api/v1/offline/backup: dial tcp: lookup ols.chaosgroup.com: no such host","message":"Cannot refresh license cache bundle","severity":"info","time":"2020-06-13T12:28:33.617225+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T12:28:34.0596305+03:00"}
                {"component":"auto_borrow_cache","message":"Loa ded license cache VM bytecode OK, checked correctness OK, cache is operational","severity":"info","time":"2020-06-13T12:31:08.532721+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T12:56:05.7788075+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T13:56:05.7782248+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T14:56:05.7794728+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T17:17:12.9226132+03:00"}
                {"component":"app","error":"failed getting session secret: Get https://ols.chaosgroup.com/auth/token: dial tcp: lookup ols.chaosgroup.com: no such host","message":"Unable to refresh session secret","severity":"warning","time":"2020-06-13T17:17:12.9734765+03:00"}
                {"component":"bundle_manager","error":"Get https://ols.chaosgroup.com/api/v1/productsData/ec9c4f57edc00aafff4ffbf840989a6292ba9824: dial tcp: lookup ols.chaosgroup.com: no such host","message":"Unable to fetch new bundles file","severity":"error","time":"2020-06-13T17:17:13.0053928+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T17:56:05.7797615+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T18:56:05.7794793+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T19:56:05.7784703+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T20:56:05.7803139+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T21:56:05.7782544+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T22:56:05.7781878+03:00"}
                {"component":"auto_borrow_cache","message":"Loa ded license cache VM bytecode OK, checked correctness OK, cache is operational","severity":"info","time":"2020-06-13T23:36:06.8217703+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-13T23:56:05.7785588+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-14T00:56:05.7786387+03:00"}
                {"component":"app","message":"Shutting down...","severity":"info","time":"2020-06-14T01:08:57.5519687+03:00"}
                {"component":"app","message":"Shutting down HTTP listener","severity":"info","time":"2020-06-14T01:08:57.5519687+03:00"}
                {"component":"app","message":"Shutting down HTTP listener done","severity":"info","time":"2020-06-14T01:08:57.6736435+03:00"}
                {"component":"app","message":"Shutting down dongle subsystem","severity":"info","time":"2020-06-14T01:08:57.680625+03:00"}
                {"component":"dongle_manager","message":"Disabl ing dongle subsystem...","severity":"info","time":"2020-06-14T01:08:57.680625+03:00"}
                {"component":"dongle_manager","message":"Disabl ed dongle subsystem","severity":"info","time":"2020-06-14T01:08:57.7005716+03:00","took":0.0179515}
                {"component":"app","message":"Shutting down dongle subsystem done","severity":"info","time":"2020-06-14T01:08:57.7274988+03:00"}
                {"component":"app","message":"Shutting down online subsystem","severity":"info","time":"2020-06-14T01:08:57.7274988+03:00"}
                {"component":"app","message":"Shutting down online subsystem done","severity":"info","time":"2020-06-14T01:08:57.7294937+03:00"}
                {"component":"app","config":{"host":"0.0.0.0","por t":30304,"data":{"directory":"C:\\Program Files\\Common Files\\ChaosGroup"},"dongle":{},"backend":{"portal ":"https://ols.chaosgroup.com"},"proxy":{"type":"auto"},"diag nostics":{"file":"C:\\Program Files\\Common Files\\ChaosGroup\\logs\\user.log","level":"info", "size":0},"monitoring":{"traceProbability":0.01,"s tackdriver":{}},"integrator":{},"file":"C:\\Progra m Files\\Common Files\\ChaosGroup\\config.yml"},"message":"Startin g Chaos License Server","os":"Windows","severity":"info","time":"2 020-06-14T01:11:27.9971686+03:00","version":"5.5.0"}
                {"component":"app","message":"Storing local activation in C:\\Program Files\\Common Files\\ChaosGroup\\ssl","severity":"info","time":" 2020-06-14T01:11:28.084935+03:00"}
                {"component":"app","message":"Current activaton is fresh, postponing reactivation","severity":"info","time":"2020-06-14T01:11:28.4529519+03:00"}
                {"component":"bundle_manager","message":"Initializ ed bundles cache to C:\\Program Files\\Common Files\\ChaosGroup\\bundles.json","severity":"info" ,"time":"2020-06-14T01:11:28.4729002+03:00"}
                {"component":"bundle_manager","message":"Updati ng bundles file","severity":"info","time":"2020-06-14T01:11:28.4738958+03:00"}
                {"component":"app","message":"Starting HTTP listener on 0.0.0.0:30304","severity":"info","time":"2020-06-14T01:11:29.024423+03:00"}
                {"component":"auto_borrow_cache","message":"Initia lizing license cache VM","severity":"info","time":"2020-06-14T01:11:29.6836553+03:00"}
                {"component":"auto_borrow_cache","message":"Loa ded license cache VM bytecode OK, checked correctness OK, cache is operational","severity":"info","time":"2020-06-14T01:11:29.6876488+03:00"}
                @Zahari.Ivanov There are some errors appears in log files from here C:\Program Files\Common Files\ChaosGroup\logs. Maybe this somehow could be the reason?
