Hello, kyle_henderson ,
Have you reached out to support@chaosgroup.com yet about this issue?
Some of our test systems are double-display setups with identical or different display scales but I am not familiar with what you describe.
Could you please answer a few questions to help me get a better idea of what may be causing all this?
Run SketchUp again and see if this resolves the faulty VFB behavior.
Looking forward to your reply!
- What is your OS and what is the custom scaling percentage value for each of your main and secondary displays?
- Does the problem occurs with every scene you render or only specific ones?
- How exactly does the VFB become unusable / not functioning as expected when running CUDA renders? Any details, as well as render progress logs will be appreciated!
