installed vray 5 for sketchup and... no materials
  • installed vray 5 for sketchup and... no materials
    like i said there is no materials iinstalled… is it a known issues? thanks
    Hello,
    We've received a couple of reports already, meaning you are not experiencing an isolated issue.
    Could you please double-check if your network-monitoring tools (firewall, anti-virus software, etc) are not blocking V-Ray's UI:
    C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayneui-win32-x64\vrayneui.exe
    Additionally, please state whether the new Light Gen tool operates as expected and is able to donwload its HDR assets (https://docs.chaosgroup.com/display/...-Ray+Light+Gen)
    Last but not least, providing log files may help in finding out what is blocking the asset retrieval. The files needed are:
    VRayForSketchUp.log located at %AppData%\Roaming\Chaos Group\V-Ray for SketchUp
    vray-neui.log located at %AppData%\Roaming\Chaos Group\V-Ray for SketchUp\vrayneui
    Just in case, please do a clean reinstall of V-Ray 5 for SketchUp and make sure you don't use admin privilege when running the installer.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      cognedur I encountered this issue and solved it by disabling my antivirus protected folder security (BitDefender), just as Peter.Chaushev mentioned.
      The option to download the assets will not be available if there are write permission issues.
      Regards
        Hi kyle_henderson,
        Thank you for sharing this.
        We'll try to handle this case in the future and at least let users know what's going on.
        Konstantin
          hey…
          Thanks for the advice… sadly Nothing is working for me right now:
          i authorized all i could find about vray on my firewall:
          Lightgen does not want to communicate with the server.
          here is the log file i found
          Please help me i have to give classes i i can't talk about materials…
          Thanks a lot
          François
            cognedur , the v5.00.02 hotfix that was just released contains change that should solve your problem.
            You can download it at https://download.chaosgroup.com/?platform=56&product=47
            Please let me know if this works!
            Peter
            Peter Chaushev
            Let's keep in touch
              YES... it's working properly now
              Thanks for the response
              Cheers
