The issue might be that the Cosmos service is not running at all on your system (it should have been started automatically).
I'd recommend you try the following:
Go to Apps And Features / Add or remove programs Windows panel
Locate Chaos Cosmos Browser
Uninstall it
Re-install V-Ray 5 for SketchUp, update 1 (Do not install as Administrator!)
I just tried to uninstall and reinstall. It did not solve the problem.
I tried to start cbservice.exe in C:\Program Files\Chaos Group\Chaos Cosmos, and it gave some errors - I will send them via DM - not sure if they can help.
Hello, Jorgensen_cg ,
Thank you for providing the log!
Could you please:
1. Uninstall Chaos Cosmos once again.
2. Once done, please make sure the following folder is deleted: C:\Program Files\Common Files\ChaosGroup\ChaosCosmos
3. Reinstall V-Ray for SketchUp
4. Make sure the Chaos Content Browser Service is running and see if the Cosmos window issue persists when opening it through the SketchUp toolbar?
Regards,
Peter
Peter Chaushev
I did what you said, uninstalled Vray, deleted the ChaosGroup folders.
I then
- reinstalled Vray
- started Sketchup
- started cosmos browser again
same result.
Then I checked sevices, and found CCBService, and it was set to "stopped", I right clicked and selected Start, it started, but when back to off in less than a second.
I then tried via services, right click, start - but it gave me an error 1067.
Thanks for the details provided. Can you please make sure you are signed in the correct account; moreover would it be possible to get in touch with us via our contact form so we can schedule a remote session and try to resolve this on the spot? Thanks!
