Chaos Cosmos Browser - no content
  • Chaos Cosmos Browser - no content
    I have just updated to the newest release, and I have an issue where the Cosmos Browser is just white.
    Is there a way I can try to fix that?
    Jorgensen
    Hi Jorgensen_cg,
    The issue might be that the Cosmos service is not running at all on your system (it should have been started automatically).
    I'd recommend you try the following:
    1. Go to Apps And Features / Add or remove programs Windows panel
    2. Locate Chaos Cosmos Browser
    3. Uninstall it
    4. Re-install V-Ray 5 for SketchUp, update 1 (Do not install as Administrator!)
    5. Go back to SketchUp and give it a shot
    Let me know if the issue persists.
    Regards,
    Konstantin
      Hi Konstantin
      I just tried to uninstall and reinstall. It did not solve the problem.
      I tried to start cbservice.exe in C:\Program Files\Chaos Group\Chaos Cosmos, and it gave some errors - I will send them via DM - not sure if they can help.
      Jorgensen
        Anyone else having this issue?
          Hello, Jorgensen_cg ,
          Thank you for providing the log!
          Could you please:
          1. Uninstall Chaos Cosmos once again.
          2. Once done, please make sure the following folder is deleted: C:\Program Files\Common Files\ChaosGroup\ChaosCosmos
          3. Reinstall V-Ray for SketchUp
          4. Make sure the Chaos Content Browser Service is running and see if the Cosmos window issue persists when opening it through the SketchUp toolbar?
          Regards,
          Peter
          Peter Chaushev
          V-Ray for SketchUp | V-Ray for Rhino | Product Specialist
          www.chaos.com
            Hi Peter
            Thanks for getting back to me.
            I did what you said, uninstalled Vray, deleted the ChaosGroup folders.
            I then
            - reinstalled Vray
            - started Sketchup
            - started cosmos browser again
            same result.
            Then I checked sevices, and found CCBService, and it was set to "stopped", I right clicked and selected Start, it started, but when back to off in less than a second.
            I then tried via services, right click, start - but it gave me an error 1067.
            I hope that you can help.
            Jorgensen
              Hi Jorgensen,
              Thanks for the details provided. Can you please make sure you are signed in the correct account; moreover would it be possible to get in touch with us via our contact form so we can schedule a remote session and try to resolve this on the spot? Thanks!
              Nikoleta Garkova | chaos.com
                Hi Nikoleta
                I use only one account on the PC, if that is what you ask for?
                I will try to use the contact form.
                Jorgensen
