Can't see the light in the mirror
  • Can't see the light in the mirror
    Hi guys, I have a problem with vray, latest version and sketchup 2021, practically as shown in the image I don't see the light reflected in the mirror, although the reflection in the light is enabled. As a computer I have an iMac Pro (2017).
    Hi luca_militello,
    Try bumping the light's Affect Reflections parameter (let's say, place a value of 100) and you should be able to see the light reflected in the mirror. See attached gif for better visual understanding.
    Nikoleta Garkova | chaos.com
      Hi luca_militello ,
      This actually has to do with the directionality parameter of the light and is 100% reproducible:
      Setting the directionality to 0 will fix the issue.
      I'll actually log this in our bug tracking system since there might be a way for us to fix it.
      As a workaround I'd suggest you make your light invisible (still emitting light) and use a light material on a peace of geometry to simulate the light mesh emission.
      You'll then have to control the material intensity independently (and manually).
      Konstantin
