VFB Compare Images
  • VFB Compare Images
    here is my problem.
    I am rendering an image.
    I save this image in the VFB history.
    I make corrections (exposure, color balance,...) on this image and I save it again.
    So I have 2 images saved, one with corrections the other without corrections.
    When I want to compare these 2 images (A & B), the corrections are not taken into account and the 2 images (A & B) are the same on the screen.
    Is this normal or a bug?
    Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.634 + V-Ray 7.00.03
    3DS Max 2025.3 + V-Ray 7.00.08
    3DS Max 2026 + V-Ray 7.00.08
    Chaos Vantage 2.8
    GeForce Studio Ready Driver Version 572.16​
    Hi DCHA34,
    Originally posted by DCHA34 View Post
    here is my problem.
    The described behavior is actually normal.
    It is however something we can look into and improve if possible.
    Thank you for bringing this to our attention.
    To compare corrections you can use the following workflow:
    # Create an empty folder to store some correction preset files (C:\temp\Corrections for example)
    # Set a preset corrections path in the VFB Settings to that folder (C:\temp\Corrections) - Options/VFB Settings/Layers/...
    # Correct your image and choose the Save layer tree preset button on the Layers panel toolbar. Save the preset in the same folder
    # Correct your image in a different way and save a new preset
    # Use the Layer presets menu to preview your corrections - just by hovering over them
    Hope that helps,
    Konstantin
