I tried to render and v- ray doesn`t recognize the GPU. I don`t know why . it is the first time this happens
V-ray GPU issues
I replied to your other thread here
We are aware of this behavior, and deployed multiple fixes for other DCCs already. A hotfix comes out soon for SketchUp
Best,
MuhammedLast edited by Muhammed_Hamed; 09-12-2021, 01:33 PM.
Hi sam_moretondeakin,
I'm sorry to hear about your negative experience.
Can you please give us more details about the issues you've faced?
If you have specific scenes causing issue, please share an example.
Thank you in advance,
Konstantin
Hi oana_bijan1 ,
Originally posted by oana_bijan1 View PostI’m having issues with all scenes ! Either complex or with simple geometry!
Does the rendering start or you see errors?
Can you share a simple scene that shows the issue?
Also it would help if you share your computer specification as well as the SketchUp and V-Ray version that you use.
Originally posted by oana_bijan1 View PostIt is useless without the GPU.
Regards,
Konstantin
The issue is and still remains that I always have the same error. With CUDA I can`t render anything. I always have the same error saying there isn`t enough memory. I even checked how much it is being using during rendering and it was not even at 10%
Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz 2.30 GHzam using the latest version of Sketchup and the latest for Vray .
I say is useless because rendering only with the CPU takes a very long time and if i still have these problems it is not worth paying every year if it doesn`t work properly .
1 Photo
We still unable to reproduce this crash on our side
Is it possible to upload a sample scene for us to investigate?
What GPU do you have on this machine? This is most likely related to your hardware, we will check and confirm
Best,
Muhammed
Originally posted by oana_bijan1 View Postokey, i can understand that, but could you be able to explain to me why before the update of v -ray i never had any problems like this?
I will test with the scenes we use internally, but feel free to upload one of your scenes if possible. It will help as well
If we still cannot reproduce I will ask you for a remote session to take a look at your setup, hopefully we get to know what the errors are about
Best,
Muhammed
