GPU interactive render problem
  • GPU interactive render problem
    i find out problem when i would to set SUN - custom orientation and i would to experiment due interactive render and change orientatiton. Vray will freeze each time, i have RTX 3090 and i try it in RTX and CUDA mode, same problem, instantly freeze. Only if i use CPU, i can change orientation and see it realtime.
    After freeze and restart sketchup is all of my section planes doubled, each one make copy of themselfs.
    Second question is about Light cache in RTX mode, this took sooooooooo much time to load even if LC is only 800 ... can you do please something with it ? CPU LC is calculated very fast.. but gpu, even with this rtx3090 card is too slow.
    zazracnedieta Hey! thanks for the report
    About Light cache, how much time does it take to calculate in your case? And does this happen with all scenes?
    In my case even at 3000 Subdivs it renders in 15 to 20 seconds for all scenes, and is much faster than CPU
    For interior scenes you actually need around 3000 LC Subdivs, which can speed up rendering a lot
    About the first issue, when you talk about a freeze? is this a crash or what happens?
    Please attach a screenshot and a simple test scene, the SketchUp team will follow along with you
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Hello, here is for example a random scene: https://drive.google.com/file/d/1GlC...ew?usp=sharing
      I try render in this modes:
      cpu - lc 3000 - 35 sec
      cpu - lc 1000 - 5 sec
      cuda cpu+gpu - lc 3000 - 28 sec
      cuda cpu+gpu - lc 1000 - 17 sec
      rtx - lc 3000 -45 sec
      rtx - lc 1000 -28 sec
      about freezes while interactive render: when i would to try set custom orientation in projects /in all projects, not just this/ when i try it with RTX mode, when i pick custom orientation and new PRG sun, and start interactive render, when i change some angle or horizontal orientation, sketchup and vray freeze, nothing is changed and i must restart sketchup. Same problem with CUDA. When i try it with only CPU, everything seems ok, no problems.. even if i choose NVIDIA denoiser.
      my pc spec: TR1950x, 64gb ram, RTX 3090 24gb..
        update: couple of times i get this error:
        11. 1. 2022 14:19:26 Error [V-Ray Asset Editor] Error: 14 UNAVAILABLE: TCP Read failed at Object.exports.createStatusError (C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayneui\resources\app.asar\nod e_modules\grpc\src\common.js:91:15) at ClientReadableStream._emitStatusIfDone (C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayneui\resources\app.asar\nod e_modules\grpc\src\client.js:233:26) at ClientReadableStream._receiveStatus (C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayneui\resources\app.asar\nod e_modules\grpc\src\client.js:211: at Object.onReceiveStatus (C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayneui\resources\app.asar\nod e_modules\grpc\src\client_interceptors.js:1272:15) at InterceptingListener._callNext (C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayneui\resources\app.asar\nod e_modules\grpc\src\client_interceptors.js:568:42) at InterceptingListener.onReceiveStatus (C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayneui\resources\app.asar\nod e_modules\grpc\src\client_interceptors.js:618: at C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayneui\resources\app.asar\nod e_modules\grpc\src\client_interceptors.js:1029:24 { code: 14, metadata: Metadata { _internal_repr: {}, flags: 0 }, details: 'TCP Read failed' }
          Thank you!
          About GPU LC, we identified the issue and looking into it now.
          About the freeze, I will type to my SketchUp colleagues to take a look
          Best,
          Muhammed
          Muhammed Hamed
          chaos.com
            good to hear it Muhammed, thank you
              Hi zazracnedieta ,
              I am not able to reproduce this issue.
              It is possible to be scene-specific. Can you share the project so that we can test on our side?
              This also sounds very strange.
              If you can create a simple project that shows the behavior on open it'll help us a lot.
              As Muhammed pointed out we're currently looking into a couple of issues which cause GPU Light Cache to be slow.
              One of us will get back to you when we make progress.
              Regards,
              Konstantin
                hello Konstantin,
                maybe is best solution to someday using teamviewer, so you can see my problems on own eyes, an vray behavior
                Iam available daily between 10-20 CET
                you or your colegue can wright my a email from my account so we can settle this
                  Please excuse me for the delay!
                  I have contacted you via email so we can arrange a remote session. Support ticket #20509
                  Let me know if you have received it.
                    slavcho.brusev
                    1. as we disqus in private emails to do some teamviewer session, i today try one thing and it seems like it helps
                    i find solution, that i need to delete /for now i just move file out and keep it / FrameBufferState.fbs from directory C:\Users\User\AppData\Roaming\Chaos Group\V-Ray for SketchUp
                    I dont know if its useful, but it seems, like this solution helps many other people with freezing during RT render
                    2. But i still have second problem and that is, that if i make section planes and close project, after opening it i have all sections planes doubled
                    EDIT: ooh, after a while, i get same problem with RT :-/ so i will contact you next week.
                      Hi zazracnedieta,
                      I was able to reproduce this issue and it's now logged in our bug tracking system - SK-3776
                      We'll do our best to fix this with the next update.
                      Konstantin
                        To give a summary from the remote session:
                        Basically, this was resolved by resetting the render settings from this button in the Asset Editor Click image for larger version  Name:	Screenshot 2022-02-10 at 10.21.57.png Views:	0 Size:	210 Bytes ID:	1139515
                        And manually readjusting to RTX engine and high resolution.
