Skatter grass causes this error on render (Original author "rusty_badge")
  • Skatter grass causes this error on render (Original author "rusty_badge")
    Hi guys,
    One of the posts in this forum section was causing issues because of its label and the message could not be accessed.
    The original forum post was deleted and the current one was created instead.
    Excuse us for the inconvenience!
    Originaly posted by rusty_badge:
    Skatter grass causes this error on render:
    [V-Ray] Error building Embree static ray caster, error message: [EmbreeRayServer::doBuildSDTree] 3: Setting vertex buffer failed (number triangles 1182275506)
    Dear Sir or Madam,
    Link to scene file above
    Whether I try to Render in progressive or otherwise the noted error...
    Here's the link to the file:
    https://onedrive.live.com/?authkey=%...&action=locate
    Hello rusty_badge
    Check if you are not running out of RAM.
    You can do that in the Task Manager under Performance > Memory
      slavcho.brusev that does appear to be the problem. Even with 128GB of DDR4 RAM. I 'solved' the problem today by removing the Skatter grass, and replacing it with a low-poly version I made myself. It gives me an OK density of grass. I'll try a different build for my next render so that I can try VRAY fur. Many thanks for the reply.
        What is the size of the terrain you were scattering the Skatter grass on?
        Did you use "Render-only"?
          The terrain is about 45mx45m. I ALWAYS use Render-Only.
            64GB of RAM should be plenty enough for a 45mx45m terrain.
            Did you import the Skatter grass as "Proxy" or "High-Poly"?
              High Poly,
                Oh, that could be the reason.
                With V-Ray, you should stick with proxies, it will be much lighter on your system.
                  JBB,
                  Thank you for the kind support: that worked a treat and looks so dang good. Thank you for taking the time to tutor me on that. Chaos' as fantastic as always.
                  Thank you.
                    I am not affiliated with Chaos, I'm the developer of Skatter
                    Although I do browse these forums once in a while.
                    I'm glad it's working fine now!
                      JBB, if I'd known that I would have been more effuse in my praise. Skatter (2) is AMAZING. It has a superb marketplace (I bought the big vines pack), and it's ability to affect by slope and the like is superb. It's one of the easiest and most intuitive programs I've used in ages. I may add that the manual makes that easy as it's full and spot on, and written in plain English. It's the first time I've seen Sketchup do a 'chaos/noise' function well, and it makes it hold it's own in some ways with something like UE4.
                      Thanks for developing Skatter it makes my life better.
                      RB
                      PS The free long grass from Skatter was sooooooo much better than my efforts.
                        Thanks for your kind words
