GPU Device Load Percentage Not Showing Up
  • GPU Device Load Percentage Not Showing Up
    I recently upgraded to Vray 6 and while I don't seem to find any faults with its operation, I have found a glitch of sorts, when it comes to showing the GPU Device Load. In previous versions, I could click on the Stats tab, and see the device name, the total memory, the used memory and the load percentage, but now I get nothing for the load. I frequently look at this tab, especially when I have large complex scenes rendering, to see how much memory is being used and its accompanying load on the device. Is there any reason why the load doesn't show up? Could it be due to my GPU not being recognized by Vray in this instance, even though it is active? Attached is a screenshot to illustrate what I am talking about.
Name:	Vray Stats.jpg
    Dear james_morvay1​, hello.
    The fault is not yours, there is unexpected behavior indeed.
    It is logged in our system with SK-4119 number and affects not only V-Ray for SketchUp.
    Thank you for reporting it!
    And please accept our apologies for the extremely delayed reply.
    You will be notified by any change.
    TS
    Tsvetomira Girginova | chaos.com
    3D Support | contact us
      Thank you for the response. So it seems this issue, combined with the blank DOS windows that appear when services are started are both fixes that are coming?
        You are on Win 11 and blank cmd windows appear? If yes, please check this forum post, where is described how to solve this.
        If not - share more details, it will be appreciated.
          Yes, that solution worked for the windows terminal windows appearing.
            Great, thank you for approving.
              No updates on fixing the GPU Load Percentage issue?
                I have shared the reminder with our devs in order to bump the priority of the issue.
                Will inform you by any news.
