This crash on close bug might still be lingering even after updating to the latest 6.2
SketchUp Close Crash
Dear ValeroStudio, hello.
Could you please confirm is the crash behaviour the same as previously described here?
It looks like we need to investigate more. Please share with us the following information:- Are you receiving BugSplat every time (share with us Crash report IDs when it happens again) or a message that SketchUp has closed unexpectedly if you try to reopen the project?
- Is something suspicious listed in VRayForSketchUp.log? Please share it with us.
- If a crash .dmp file is created could you please again share it with us?
- Could you try starting SketchUp via Command Prompt and save the work process in a .log file? See the visual example here. After you close SketchUp and there was a crash, share the generated .log file too.
- Are there any pending updates - Win or SketchUp?
- Is it happening also with blank new files (unsaved)?
- How often is it happening - every time, from time to time, when changes to file are/aren't applied before closing?
Please collaborate as usual by answering the questions above.
The cause should be found.
TS
Hi ValeroStudio,
The crash on exit is addressed in a hotfix which was just released:
https://forums.chaos.com/forum/v-ray...-now-available
Please let us know if the issue is resolved,
Konstantin
KonstantinMatthew Valero, ASAI
Hello, Matthew,
Our dev team will look through the files you shared.
Is it safe to assume the crash is reproducible solely with a specific SketchUp model?
Peter Chaushev
V-Ray for SketchUp | V-Ray for Rhino | Product Specialist
www.chaos.com
Is it safe to assume the crash is reproducible solely with a specific SketchUp model?Matthew Valero, ASAI
- Likes 1
