I upgraded from Vray 5 and Sketchup 2019 to Vray 6 and Sketchup 2023.
Clean Windows install.
Celan Sketchup and vray install.
Some fabrics materials I created previously are presenting problems. This materials have a falloff map in diffuse, with a bitmap of a fabric and the same bitmap fabric wrapped in color correction slightly lightened. They also have the same fabric bitmpap wrapped in color correction in bump to get some texture.
In the sketchup viewport they appear with white seams.
In the material preview sometimes they do, sometimes they don't. The ones that do, have lost the diffuse bitmap but not the bump bitmap.
The ones that render incorrectly (as far as i know) are models imported with the materials already applied, that previously rendered correctly.
I daily render furniture with textiles, and I have created a large library of materials that worked properly in the previous versions.
What can I do for you to help you fix this bug?
