Here is what I did.
Run DRSpawner.exe at slave computer.
Add the IP of slave in the setting
check 'enable asset collection' and 'send to shared folder' and select network folder which can be used for both computers.
When I try render, I can see 4 buckets w/ two computer's names at the first frame only, then it seems like normal - only 2 buckets of mine. I used incremental IR+LC.
I check the CPU usage of slaves. At the first frame it's aboout 90% used, after that it changes between 0 to 20~30% and and it doesn't say any error.
Why does this happen?
Please help!!!
Tj
p.s.
By the way it's very sad when I find out VFR logo at the 'About' menu in the VFSU! :P
Please help!!!
Tj
p.s.
