Slowdowns in material editor
  • Slowdowns in material editor
    hi all,
    Title says it all.
    Sometimes the material editor slows down , most of the time when trying to assign a vraymat to objects or when editing a component or materials nested in components or when deleting a vraylinked material etc...
    Perhaps this is not a bug...more something that needs to be optimised in terms of memory manangement?
    Re: Slowdowns in material editor
    i have it too.
    But if you have many objects this one material like components(i have it from import from archicad), try to make single "mesh" with texture: explode items and group it by texture...
    Ilay
      True,
      But exploding isn't good in my case because that would screw up my file.
      I work using layers and groups/components so they can be switched off on hugh model files.
      Otherwise Sketchup stands still (SU has a major memory leak/optimisation issue).
      Exploding would make editing impossible...
      But thanks for that tip. For smaller files this is useful.
        When you are applying a material to many sub-objects it will definitely take some time. But if you are experiencing this slowdown with only a few sub-objects then there is definitely a problem. But I'm always on the look-out for ways to speed up our interactions with Sketchup.
        Joe Bacigalupa
        Developer
        Chaos Group
