Texture Bitmaps Missing in Linked Materials
  • Texture Bitmaps Missing in Linked Materials
    Hey Everyone,
    I haven't been able to find any posts with this exact problem so here goes...
    When I create a Vray linked material from a sketchUp material, it seems to be working for the most part, as it shows up in the Vray material
    editor, but when I click on the big "M" in the diffuse layer the bitmap for the texture map is missing. If I render or hit update in the material preview it displays the diffuse colour of the material but not the texture bitmap.
    I noticed that sketchUp isn't referencing actual bitmaps as it appears to be under edit in the material window, but a .skm file. Do you need to extract the bitmaps from the sketchUp materials somehow so that VRay can reference them... I'm sure if that was the case I would have come accross it by now.
    I installed the demo on my office computer and it works fine... so I'm stumped. Has anyone else experienced this problem?
    Thank you kindly for taking the time to read this.
    Sincerely,
    Matt Schmid
    Re: Texture Bitmaps Missing in Linked Materials
    Could you send me a file that demonstrates this ? If the Sketchup material you are linking to has a diffuse bitmap - then our linked material should as well. I've not experienced this issue myself.
    Joe Bacigalupa
    Developer
    Chaos Group
      I find this problem too!! Not before today but it started 5 mins ago!
      I apply a material in SU with a diffuse texture but when i create a linked mat no texture shows in the diffuse slot: i only obtain a gray color as a map AND a preview of the material..
