"Sketchup has stopped working" <--That's what I've been receiving. The attached image is a sample of what I am working with.
I have these massive concrete block blade walls and for them, I am using a reinforced concrete material map. The material is exactly what i want, only i had some difficulty with bump so I scrapped that all together and believe it or not, built each "block." If you look at the attached image, you can see that the wall is just one solid mapped with individual concrete block "panels" separated specifically to create mortar gaps.
Each panel has the concrete material map applied to it. If you notice by this render, only one side of the wall is paneled. The opposite side and all the inner sides of the view window are un-paneled. Why? Because if i panel anymore than 1 side, sketchup "stops working" right as the render image box pops up.
I tried exploding all the panels. But I know for a fact the panels are fine, the render works perfectly (all panels on all sides render) but only without the conc material map. It definitely has something to do with the material but I have no idea what...
Can anyone think of any reason why adding regular sketchup material maps (keep in mind without bump or anything like that) would just stop sketchup all together? I am desperate to resolve this!
Thank you!
forgive the mediocre image...
Thank you!
