Hello, I started getting this bug just last week... it never happened before... is it possible that its related to Sketchup 7.1 (which I installed recently)???
Basically, what happens is that I start rendering and it all runs normal until the final pass (after all prepasses). Then some (or many) of the squares get black instead of showing the image.
The error of the topic title appears on the Render Progress Window... DURING the prepass...
Setting up 4 thread(s)
Exception: Memory allocation failure; 1680000 bytes requested; 892645812 bytes already in heap; 9759872 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 892645788 bytes already in heap; 9759616 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 892645764 bytes already in heap; 9759360 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 892645740 bytes already in heap; 9759104 bytes free heap space.
Exception: Irradiance map thread
Exception: Memory allocation failure; 1680000 bytes requested; 900339056 bytes already in heap; 9250024 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900339032 bytes already in heap; 9249768 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900339008 bytes already in heap; 9249512 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900338984 bytes already in heap; 9249256 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900338946 bytes already in heap; 9248976 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900338204 bytes already in heap; 9247992 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900338166 bytes already in heap; 9247712 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900338128 bytes already in heap; 9247432 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900338090 bytes already in heap; 9247152 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900338052 bytes already in heap; 9246872 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900338014 bytes already in heap; 9246592 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900337976 bytes already in heap; 9246312 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900337938 bytes already in heap; 9246032 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900337900 bytes already in heap; 9245752 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900337886 bytes already in heap; 9245728 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900337464 bytes already in heap; 9244976 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900337426 bytes already in heap; 9244696 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900337388 bytes already in heap; 9244416 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900337350 bytes already in heap; 9244136 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900337328 bytes already in heap; 9243784 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900336250 bytes already in heap; 9242464 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900336212 bytes already in heap; 9242184 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900336174 bytes already in heap; 9241904 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900336136 bytes already in heap; 9241624 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900336114 bytes already in heap; 9241272 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335660 bytes already in heap; 9240576 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335646 bytes already in heap; 9240552 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335608 bytes already in heap; 9240272 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335594 bytes already in heap; 9240248 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335580 bytes already in heap; 9240224 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335566 bytes already in heap; 9240200 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335936 bytes already in heap; 9240240 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335914 bytes already in heap; 9239888 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335876 bytes already in heap; 9239608 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335838 bytes already in heap; 9239328 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335800 bytes already in heap; 9239048 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335762 bytes already in heap; 9238768 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335724 bytes already in heap; 9238488 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335686 bytes already in heap; 9238208 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335648 bytes already in heap; 9237928 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335610 bytes already in heap; 9237648 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335572 bytes already in heap; 9237368 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900335534 bytes already in heap; 9237088 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900334480 bytes already in heap; 9236024 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900334442 bytes already in heap; 9235744 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900334404 bytes already in heap; 9235464 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900334342 bytes already in heap; 9234928 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900334304 bytes already in heap; 9234648 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900334266 bytes already in heap; 9234368 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900334252 bytes already in heap; 9234344 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900334190 bytes already in heap; 9233808 bytes free heap space.
Exception: Memory allocation failure; 1680000 bytes requested; 900334176 bytes already in heap; 9233784 bytes free heap space.
then, after it completely finishes rendering the image, I get a bugsplat!
