DR Spawner Crashes "Runtime Error" DR Timeout
  • DR Spawner Crashes "Runtime Error" DR Timeout
    At my office I have set up 10 computers for distributed rendering. It has worked beautifully in the past, but just recently, the DR is have problems. This is the most notable response from my Render Progress bar:
    Render host 10.10.1.99 added
    Scene transferred to lab11
    Bitmap file "C:\ProgramData\ASGvis\VRayForSketchUp\Textures\Me tal_Seamed.jpg" loaded.
    Server 10.10.1.99: Scene loaded; starting render.
    Server 10.10.1.99: Starting frame 0.
    Render host 10.10.1.120 added
    Scene transferred to lab14
    Render host 10.10.1.93 added
    Scene transferred to lab13
    Render host 10.10.1.104 added
    Scene transferred to lab12
    Ping not received from host 0.0.0.0 for 59406 milliseconds, dropping connection.Render host unknown (10.10.1.120) is not responding
    Ping not received from host 0.0.0.0 for 62057 milliseconds, dropping connection.
    Render host unknown (10.10.1.93) is not responding
    Render host unknown (10.10.1.104) is not responding
    Ping not received from host 0.0.0.0 for 51949 milliseconds, dropping connection.
    Ping not received from host 0.0.0.0 for 57408 milliseconds, dropping connection.
    Ping not received from host 0.0.0.0 for 58188 milliseconds, dropping connection.
    In all cases, it has something to do with the DR timing out. I am curious if anyone has run into this issue before. I am trying to think of reasons why it would be timing out and I am not entirely sure.....network connection speed? All the computers are linked via a company network, and they are all running on Windows Vista 32 bit OS.
    Re: DR Spawner Crashes "Runtime Error" DR Timeout
    If you switched to the recent release (1.48.66), yes, it is normal.
    DR is buggy and will be fixed in a soon up coming patch...
      Hmmmm interesting. Do you happen to know if this might have anyting to do with whether you "Send to each node" or use a "Shared Folder" for the DR?
        I'm not specialist, but I think it is not related.
        On my system, I left the "Send to each node" checked...
