Vfs causing sketchup to run slow and crash?
  • Vfs causing sketchup to run slow and crash?
    Over the past couple of days Sketchup has been running very slow in opening and saving model files, and crahsing periodically. I thought it was just because the model I am working with is rather large (14mb), but after a few tests, I think it has to do with vray. I'm using Mac OSX 10.5.8, Sketchup 7.1.6859, and the vray trial 1.48.66.
    I was not sure if it was vray or sketchup causing the problem, so I did a few checks. I used the same model file for all tests.
    First, I went to my bootcamp Windows XP and installed a fresh sketchup and the vray trial - it worked fine. Model loaded and saved quickly, no lag, no crashing, great. Therefore, I thought maybe my OSX apps were at fault.
    So I then went back to OSX and uninstalled both sketchup and vray in order to start fresh. I first reinstalled sketchup only and all was fine. I then installed a fresh vray trial, and upon opening sketchup, it reverted back to the lagging load and save times.
    Any ideas to what the problem is?
    Re: Vfs causing sketchup to run slow and crash?
    Im having the same issues. Its an OSX thing i guess
      There have been some reported lagging UI issues, which I believe our latest beta version fixes. So hopefully this won't be an issue when we release the next patch. If either of you would like to test it out, just sign up here: http://forum.asgvis.com/index.php?topic=7679.0
      Devin Kendig
      Developer
      Chaos Group
