File crashes with version 1.49.01
  • File crashes with version 1.49.01
    Hi to all.
    I've been rendering this scene successfully with the previous version of Vray. But now that I've updated to version 1.49.01 it keeps crashing. (probably because of RAM limitations). Is there any reason why it would work before and not now? Is there anything I can do to fix this?
    Thanks to everyone!
    -Juan
    Re: File crashes with version 1.49.01
    This is the error report I'm getting.
    =========System Information=========
    platform = win32
    country = UnitedStates
    language = English
    About to make our qapp
    after make qapp
    Made it after UIManager.initialize
    C:\ProgramData\ASGVIS\Python26\Lib\site-packages\Ft\Xml\InputSource.py:346: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
    FtWarning, 2)
    FtWarning: Creation of InputSource without a URI
      the error log has nothing in it, do you know how much RAM is being used? Our plugin does take up a bit more memory than it used to, so if you were just barely able to squeak by with the old version, the additional memory that the plugin takes up might be pushing it over the edge.
      Devin Kendig
      Developer
      Chaos Group
        Hi Devin,
        yeah, I think I was pushing it to the limit.... it was pretty much a test to see how many cars, trees and people I could add without it crashing.
        I was rendering it at 7000 pixels wide by 2500 pixels high... but with the new vray, I can't get it to render anything larger than 1280 pixels wide.
        Is there any workaround to this? If not I'll probably have to reinstall the older version!
        Thanks for your time.
        -Juan
          the only way to find out for sure if it's a RAM limitation, is by looking at how much memory SketchUp is using while you render. You can look at how much RAM is being used by using the windows task manager.
          Devin Kendig
          Developer
          Chaos Group
            I believe it was crashing at around 1.5Gb
            There were a couple of times though, where it didn't crash.. it looked like it was parsing, it said vray was preparing to render the scene and then it just stopped. At first I thought I'd forgotten to press the render button, but it happened a couple of times.
              I sent the file to Fernando as per his request... maybe he'll be able to find something.
              Thanks again for your help! YYou guys have great support!
                Hi ARQRAMOS
                I was able to render the scene at 7000 without any troubles. During the rendering my computer used 3.2 GB of ram. I'm wondering what kind of computer you have and also yous system specification. I guess Devin is right, you could be running out of memory. You could try to use VRImage to make the render.
                Best
                  Thank you Fernando! Do you use the patch to allow sketchup to use more than 2gb of ram? Would that solve my problem?
                    the latest version of SketchUp 8 allows you to use more than 2gb of memory.
                    Devin Kendig
                    Developer
                    Chaos Group
                      what the what? that's awesome. Well... that certainly changes things.
                      Thanks Devin and Fernando!
                      If you have any other tips on how to make my render better, I would really appreciate them! Take care!
                      -Juan
                        http://sketchup.google.com/support/b...lease_notes.cs
                        http://forums.sketchucation.com/view...p?f=80&t=34299
                        Devin Kendig
                        Developer
                        Chaos Group
                          SketchUp8 Maintenance Release 1 if you have an 64bit OS.
                            Thanks Thomthom.... and thanks for all of your plugins!
