Trying to add a z-depth channel for use in photoshop and keep coming up with this effect - z-depth clamp is ticked so don't understand why this is happening
Z-Depth Problem
As a jpeg is this the problem?
The rendered image is a jpeg and so is the VFB channel
Not using a physical camera but an hdr image for the GILast edited by agentorange_cg; 16-07-2012, 11:15 AM.
I also come across this same problem. One thing I found is that if I use the lens shift, these strange blocks appear and when I set it to zero (ie. not correct the perspective) they disappear. Maybe it only works here and in certain situations, but it could work for you to? Good luck!AMD Ryzen 9, RTX 2080Super, ArchiCAD 24, Vectorworks 2020, Sketchup 2021 Pro, Vray Next for Sketchup, Skatter, Twinmotion 2020
