V-ray 3.4.004 issues
    When I import this proxy in an empty file, after that I import the this one, the Multi material will be merged.
    Note that the Multi Material name for the first proxy is "Proxy_MtlMulti_Component#11", and for the second one is " Proxy_MtlMulti_Component#6"
    I have fixed this issue by making a unique name for each one.
    Most of time I create the proxy in an empty file, so the "Proxy_MtlMulti_Component#X" is most common name and it could make a confliction with other Skp proxies Multi materials with same names.
    Regards,
    Mousa Abu Doush
    Architect | 3D Artist
    www.sketchuparchive.com
      Hello, Mousa,
      Thank you for the additional info about the render view position change!
      We'll also investigate the BOXTREE .vrmat bug.
      Regarding the proxy material names, I was not able to reproduce the issue using the files you provided.
      The way V-Ray proxy materials are being labeled in the latest versions should not cause this naming issue. Even upon importing the same proxy file in several instances, instead of using a single one, automatic name indexing should differentiate between each MultiMtl. The current label suffix is "[vrmesh name]" material for the MultiMtl, and "[MultiMtl] sub-material" for the its sub-materials. Introducing the same MultiMtl indexes each one with #1, #2, etc.
      I'll get back to you as soon as we have an update on the current issues. Possible fixes will be introduced in the next update.
      Peter Chaushev
      www.chaos.com
        Hi Peter,
        Thanks for taking these issues in your consideration, I have made this screencast for the the proxy material names issue I have mentioned.
        Regards,
        Mousa Abu Doush
          We're on it.
          Thank you for the video demonstration!
          Kind regards,
          Peter
          Peter Chaushev
          www.chaos.com
            Thank you !
            Regards,
            Mousa Abu Doush
            • #21
              Quick update:
              - the camera lock issue will have a solution introduced in the upcoming update.
              - the proxy material issue cannot be fully resolved at this point.
              Kind regards,
              Peter
              Peter Chaushev
              www.chaos.com
              • #22
                Hi Perter,
                Thanks for the update. Until the second issue is solved, could you provide with some info for what exactly causing this issue and how to avoid it?
                I got another issue, the attachment contain 2 skp, each one has a V-ray glass material with the same name, but the file with name "Glass test 2" the opacity for the SketchUp materials is set below 100, when I import ""Glass test 2" inside "Glass test 1" the glass material for the imported object will turn to a standard material .
                Regards,
                Mousa Abu Doush
