Projected Texture Issue
  • Projected Texture Issue
    I am stumped on this one - a projected texture of the site aerial is not rendering with the mapping that's applied in SU. I have checked front faces back faces, removed the material and reapplied it and I am just lost at how to fix it.
Name:	Projected Texture.JPG
    Matthew Valero, ASAI
    Not sure what the issue was/is but I was able to get it the render correctly by projecting the texture to a flat plane above the terrain, click Make Unique Texture, then reapply it to the terrain.
      Good to hear you found a work-around. Have you found any good solutions to finding decent aerials? (I've just been using GE Pro & municipal GIS....)
      Core i7-8700K @ 5 GHz, Kraken X72, Asus - ROG MAXIMUS X CODE, Trident Z 64 GB @ 3000 MHz, 2x Samsung - 970 Evo, 2x EVGA - GeForce RTX 2080 Ti, Phanteks - Evolv X, SeaSonic - PRIME Ultra Titanium 1000 W, CyberPower - CP1500PFCLCD, 2x BenQ - PD3200Q, 2x Loctek D7L Monitor Arms, Corsair - K70 LUX RGB, 3Dconnexion SpaceMouse, Logitech - G602
      Windows 10 Pro, Vray 5 for 3DS Max (latest), 3DS Max 2022 (latest), Vray 5 for Sketchup (latest), Sketchup Pro 2021 (latest)
        GE Pro is my go to. I use it in conjunction with DanielTal GE Maker plugin and have been happy with it.
          I didn't know about that plugin...just checked it out. Thanks for the tip!
            Kindly note that we are aware of this behavior, which stems from the way SketchUp handles projected textures. Unfortunately, for the time-being we do not have a solution.
            There is another forum post regarding this with some additional info why it occurs.
            https://forums.chaosgroup.com/forum/...-textures-bugs
