Material ID - not a default?
  • Material ID - not a default?
    What's the reasoning that Material ID needs to be added as an attribute separately when making new materials? I was wondering why a lot of materials on the ID channel were rendering black and just recently realized that it is not a default material property. That doesn't seem like a good thing to me.
    Matthew Valero, ASAI
    There is now a better way to generate random colors based on material assignments - with the Material Random Color element.
    The material ID attribute is actually a shading effect that slows down the rendering calculations (a little bit but still).
    That's why we implemented this new element in V-Ray Core that does a similar thing without any shader modifications.
    It is similar to Cryptomatte but outputs an 8bit image, works in interactive and on GPU.
    Hope that helps,
    Konstantin
      I have found that this also produces black for some materials though.Here is a render I did last week. Random Color did not create ID for 3 of the materials in this example.
        Now, that is strange.
        Can you share the scene for investigation on our side?
        Vrscene also works...
          Thank you for the scene Matthew.
          I found the issue and it's not gonna be very trivial to fix.
          The Random color does not work for meshes that have the front and back faces painted with a different materials.
          One of the materials can also be inherited from the Group / Component - it's still a problem.
          To find such situations in the scene you can use the Scene Interaction Tool.
          The following 2 examples will cause issues:
          You can sort of work around that by making sure that both front and back faces use the same material.
          Note that a default material assigned to the back will not cause the problem - it's handled differently by V-Ray.
          It also seems that the problem is not there on GPU - the GPU handles this situation just fine.
          I'll log this but it'll require a change of V-Ray Core to be resolved.
          Thank you for reporting it.
          Regards,
          konstantin
            I understand. Thanks for looking into it.
              Hi Matthew,
              The issue we discussed here is now fixed.
              You can read more about this latest update here:
              https://forums.chaosgroup.com/forum/...-now-available
              This particular fix was challenging but I think we got it right this time around.
              Let me know if you find anything else.
              Regards,
              Konstantin
                That's great news. I also see the material colorize bug squashed, I experienced this on many occasions but I never got to the cause of it.
